Flow Designer - Need to run catalog task in loop
abhishekrav
I have a Requirement that , If a the approver approves the request and moves into if condition.
- A new catalog task is created for procurement of the device.
- After completion of that task , new catalog task is created to configure the device.
My requirement is:
- In configuration task If the device is damaged or not in state to use so we need to create a new return task and start the loop of procurement again for max 3 times.
I have attached the screenshot of the flow design. Please let me know your approach to the problem.
Thanks for your Answer, But you did not understand my requirements.  I don't want it to run for 3 times if it is damaged , If the received product is damaged it should go back to procurement task but if second time if it successful it will end the flow .
