Flow designer script on wait for condition not working
CharlesG2504556
I have a flow in which I am creating a REQ/RITM/SCTASK and then trying to wait for all of the tasks on the RITM to complete. Here is the wait for condition I am trying to use:
and the script:
var tasks=new GlideRecord('sc_task');
tasks.addQuery('request_item', fd_data._2__create_record.record.sys_id);
tasks.addQuery('state','<',3);
tasks.addActiveQuery();
tasks.query();
if (tasks.next()) {
answer = false;
else {
answer = true;
For whatever reason, it falls through every time. I even tried switching answers to see if that would fix it. It falls through no matter what.
Here is the flow:
Am I missing something? Is there supposed to be another step somewhere?
Thank you,
Charles
Balaji Jagannat
I see that your "Wait for Condition" is on the Requested Item table, but you are not returning any real filter condition for that table through the script.
In your step#3, you are creating some task, is that the task associated with RITM or something else? I'm trying to see whether you can set your "Wait for Condition" on the sc_task table itself an avoid the need to script?
16 REPLIES 16
try this,
Ashutosh Munot1
HI,
Is this true?
What is _2__create_record?
Also try state=3 instead of <
Ashutosh
Access Flow/Action data using the fd_data object. The _2__ means step 2.
I only want it to exit the wait for when the state is completed. Therefore, I need it to be < 3.
HI,
Yes so you can try state = 3 and test.
Also check the log
gs.info('ID : '+fd_data._2__create_record.record.sys_id);
tasks.addQuery('state',3);
tasks.query();
if (tasks.next()) {
answer = false;
else {
answer = true;
Ashutosh
Balaji Jagannat
