01-16-2025 10:07 AM - edited 01-16-2025 10:12 AM
I have created set flow variables. But my script is not working to call set flow variables.
here is my script : return fd_data.flow_var.json;
01-16-2025 10:50 PM
you are trying to set the value of flow variable to a additional field ,so may the issue is with data type check the type of additional field, your variable type is JSON so may be additional fields is not accepting type as Json.
01-16-2025 11:21 PM
the flow variable is of type JSON
Is the additional field input for that Create Issue action accepting JSON type?
It's because of the mismatch possibly
01-16-2025 10:50 PM
01-16-2025 11:21 PM
01-19-2025 07:04 AM
Hope you are doing good.
01-17-2025 02:23 AM
Hi @krishna115
Could you please let me know why you are not using the flow variable data pill instead of returning the value via scripting ? Also, could you please confirm the data type of Additional field of your custom action and what action it is intended to do ?
Thanks and Regards
Amit Verma
