Flow designer to validate true/false system property
Kumar38
I created a flow designer that triggers when a value of T/F property changes to true , It doesn't trigger when I update property to true.
It works when I click on test and use the same property as example. Later in one of the steps , there is a if statement to validate if its true . that steps always fails although its true.
can this be triggered/validated on a system property ?
Vasantharajan N
Tera Sage
Please define a flow variable of type true/false and set the flow variable using the property value then use flow
variable for if condition
Hi , Can you please check this . I initially thought this is working .
https://www.servicenow.com/community/developer-forum/unable-to-validate-true-false-false-property-in...
newhand
In fact .. the scripts may get lost with unknow reason...(It happened many times for me ..)
However it happens on the version roma ( i don't know if it has be fixed ...)
