Flow designer wait for condition is not working
SHALIKAS
I have the below script for wait for condition action
 var dec_date =fd_data._2__get_catalog_variables.decommission_date;
var nowTime = new GlideDate();
if(dec_date<=nowTime)
    answer = true;
else answer =false;
While logging nowTime and dec_date the format for both is coming as yyyy-mm-dd.
But the flow is not waiting
Satishkumar B
Hi @SHALIKAS
try using GlideDateTime instead of GlideDate for accurate comparisons
// Convert the decommission date to a GlideDateTime object
var decDateTime = new GlideDateTime(fd_data._2__get_catalog_variables.decommission_date);
// Get the current date and time as a GlideDateTime object
var nowDateTime = new GlideDateTime();
// Compare the two GlideDateTime objects
if (decDateTime <= nowDateTime) {
    answer = true;
    answer = false;
Mark it helpful 👍and Accept Solution ✅!! If this helps you to understand.
Still not waiting ,
while logging dec_date and nowTime it is coming as
today date 2024-07-31 07:55:46 and dec_date is dec date2024-08-03 00:00:00
bit the wait for condition is not waiting
Hi @SHALIKAS
Yes, the dec_date will be of future only, so will it not compare the future date?
