Flow working on test but not Automated
markdart
I created a flow that works when i test but not when it runs in background.
Flow is triggered on contact creation.
It grabs the userid into the variable I then grab that variable and update the email address with adding @email.com.au *not actuall but here for reference.
in both cases on test and Austomation the username is populated into the variable. But in the automated test I dont get any info back into the email variable.
Script running
var sum = fd_data.flow_var.username + '@email.com.au';
return sum;
ok the stangest thing I was testing some other suggested code which hadnt worked so I put in my original code like I first had tested to get some screenshots and now its working without running as system user or anything else. very Strange
J Siva
Hi @markdart
Are you getting any error? Have you checked the logs in the flow execution?
Siva
JerryJ071847183
Tera Sage
I think:
The issue you're facing is likely due to timing or data availability when the flow runs in the background.
When you run it manually (via "Test"), the record is fully saved and all values are available.
But when triggered automatically on contact creation, some fields (like username) may not yet be committed to the database.
Try something like this :
var gr = new GlideRecord('table_name'); // or 'customer_contact' if you're using CSM
if (gr.get(fd_data.flow_var.contactSysId)) {
var username = gr.user_name || ''; // Adjust the field name as per your contact table
return username + '@email.com.au';
return '';
NOTE : modify the script as per your USECASE accordingly.
I got nothing back on my manual test. Updated table in script and check field name is correct
var gr = new GlideRecord('customer_contact'); // or 'customer_contact' if you're using CSM
return '';
Ankur Bawiskar
@markdart
please share complete flow steps screenshots
any error in flow execution?
