get business duration using metrics definition and schedule
yandp
Hello all,
I am getting business duration using metrics definition and schedule.
the schedule i tried is the 8-5 weekdays, as an example below based on the start and end date, is this correct?
it only take 8 to 5 everyday sum up and divide by 24  => 6 day ++ ?
if i want to make it as from Monday to Friday = 5 days, instead of by hrs, is that possible ?
how to set the schedule?
I tried as below, but the time calculated is not correct.
example below, showing 22 hrs as business duration.
Hope to hear from you any idea how to do this.
Thank you.
Hitoshi Ozawa
Hi Yandp,
Schedule will only calculate duration based on the time within the schedule. That is, if 8-5 weekday is selected, it would only add 9 hours each day on weekdays.
By selecting "All day", it would imply adding 24 hours each day.
"Day" in duration is not the actual number of days but number of hours/24 hours. It's actually person-hours as is used in project management.
@Hitoshi Ozawa
Thank you Ozawa san for the details sharing, it helps me.
