02-01-2019 10:38 AM
I have a catalog item where I have a reference field to sys_user table (Requested for).
In Some fields on the form only the following users can enter values - requested for's manager, requested for manager's manager, User access administration group. To other users the fields should be visible but they cannot enter values.
I have written a Script Include and Client Script for this but it is not working. I am new to ServiceNow and not too good with coding. Can someone please point out my mistakes?
Please someone help me correct the code?
Script Include -
var RestrictAccessToUpdateFields = Class.create();
RestrictAccessToUpdateFields.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getAccess: function() {
var obj ={};
obj.retvalue ='';
obj.mm = '';
obj.grp = '';
var a = this.getParameter('sysparm_user_id');
var manager = new GlideRecord('sys_user');
manager.addQuery('sys_id', a);
manager.query();
if(manager.next()){
obj.retvalue = manager.manager.sys_id;
obj.mm = manager.manager.manager.sys_id;
obj.grp =gs.getUser().isMemberOf('User Access Administration');
return JSON.stringify(obj);
type: 'RestrictAccessToUpdateFields'
Onchange CLient Script
var id = g_form.getValue('requested_for');//newValue
var ga = new GlideAjax('RestrictAccessToUpdateFields');
var a = g_user.getUser();
ga.addParam('sysparm_name','getAccess');
ga.addParam('sysparm_user_id',id);
ga.getXML(CallBack);
function CallBack(response)
var returneddata = JSON.parse(answer);
if(returneddata.retvalue == g_user.userID || returneddata.mm == g_user.userID || returneddata.grp == true ){
g_form.setReadOnly('updated_first_name', false);
g_form.setReadOnly('updated_last_name', false);
else{
g_form.setReadOnly('updated_first_name', true);
g_form.setReadOnly('updated_last_name', true);
02-03-2019 07:42 AM
getUser method is not available in g_user and also in script inlcude your code returns the objects instead of sys id of managers
Try the below script
Script Include -
var obj ={};
obj.retvalue ='';
obj.mm = '';
obj.grp = '';
manager.query();
if(manager.next()){
obj.retvalue = manager.manager.sys_id.toString();
obj.mm = manager.manager.manager.sys_id.toString();
else{
02-02-2019 08:08 AM
Yea, after reading a bit more, I missed the part about this being a catalog item. ACL's then really wouldn't help here.
02-02-2019 10:26 AM
oh ok, then I guess I have to work with GlideAjax only
02-02-2019 06:38 AM
HI,
Check this website. Maybe you will find some interesting information.
02-02-2019 07:29 AM
Hi Ram, if I use g_scratchpad for my requirement, how can I write the code for getting requested for's manager and requested for manager's manager in the display business rule?
02-03-2019 06:03 AM
Hi Ram,
I tried the below code( just for the group restriction) but it is not working -
Display BR-
function userIsMember() {
g_scratchpad.isMember = gs.getUser().isMemberOf('User Access Administration');
})(current, previous);
Client Script -
function onLoad() {
var myVariablesAreReadOnly = false;
if (!g_scratchpad.isMember) {
myVariablesAreReadOnly = true;
g_form.setReadOnly("variables.updated_first_name",myVariablesAreReadOnly);
g_form.setReadOnly("variables.updated_last_name",myVariablesAreReadOnly);
