GlideDialogForm set view not working for users but works for admin
Chandler B
Mega Contributor
I have a GlideDialogForm popup for the customer_contact form that I want to display in a certain view. When I run it as an admin, it opens correctly in the view I set regardless of what view I have last viewed the form in. When I run it as a user it opens in the last view (possibly their preference view) they viewed the customer_contact form in. They do have access to set their view to the one I want to open as if they are on the form. To set the view, I run this before rendering it:
dialog.addParm('sysparm_view', 'Requestor2');
Why is this only working as an admin?
Weird that should have forced the view do you have avy view rules can uou check once?
Ahhh there was an OOB view rule for the customer_contact table that was forcing the view. Thank you!
Do you know of a way to bypass the view rule in the popup only? Otherwise I assume I will have to just modify/disable that rule based on needs.
Hello
Yes you will need to modify thexruke as view rule will override our ui action
