12-09-2022 12:19 AM
Hi
I have raised a two RITMs that are a part of one request (REQ#######)..
Here my defect is I need Two "request for" fields in two RITMs should be same..but it is working only for one
For example
RITM for 1st( RITM11111)
Request for = aaaa
under variables
request for = aaaaa
where as for 2nd RITM(RITM22222)
Request for = aaaa
under variables
request for = bbbb
Here i need for 2nd RITM (RITM22222)
request for = bbbb
under variables
request for = bbbb
12-09-2022 12:34 AM
The requested_for field is not actually a field on the sc_req_item table, but on the sc_request table.
If you right click the field on sc_req_item table and select show - 'requested_for' it will open a small popup that shows "sc_req_item.request.requested_for".
Each Request is therefore always for 1 person no matter how many RITM's you include.
Rather in your case you could consider that if manager (or whoever) is ordering the RITM's then they'd be the requested_for for all and then separately have a variable which holds the actual recipient.
Otherwise you'd have to create your own custom requested_for field on sc_req_item and use that instead.
12-09-2022 01:06 AM
Hi
And also please share screen shoot for it if possible like how we can proceed
12-09-2022 01:18 AM - edited 12-09-2022 01:19 AM
@Dileep Raju Tried and tested solution
Create a Business Rule on RITM as follows
Script:
current.requested_for = current.variables.requested_for;
})(current, previous);
Please mark as correct answer if this solves your issue.
12-09-2022 02:12 AM
@Dileep Raju Cant' exactly say why its not populated in second RITM? It depends on the logic you built in the catalog item and workflow.
Which screen shot you want i did not get that?
12-10-2022 08:27 PM
@Dileep Raju There are 2 "Requested for" fields on the RITM table, one is its own field and one more is the "Request" table field. (please see image below)
In list view above you can see those 2 fields.
In the form view you can notice the field "Requested for" added on the form is of "Request" field not of RITM field.
And "Requested for" of Request is only one person.
And through our script we are populating the RITM "Requested for" field. So please add the RITM "Requested for" field on form OR check the RITM "Requested for" field populated in the list view.
12-09-2022 02:37 AM
Its not working properly any other answer please
12-09-2022 02:38 AM
@Dileep Raju What is the issue? can you please add the screen shots.
12-09-2022 03:28 AM
I am unable to get request for same in two ritm
12-10-2022 06:28 AM
Hi @jaheerhattiwale
variable is from variable set .....so code is not working could you please help me???
12-10-2022 07:20 AM
@Dileep Raju Oh, then please change the code as below
current.requested_for = current.variables.<VARIABLE SET INTERNAL NAME HERE>.requested_for;
