Help - For Loop in Client Script
ktjstn
Kilo Expert
 I want to auto-populate the equivalent Server Environment of each Server CI selected in Server CI (List) field. But I am only getting the first value and the rest was just a comma.
Here are my scripts:
1. Script Include:
2. Client Script:
Thank you for your answer! 🙂
hvrdhn88
Giga Patron
try now.
Script Include:
var watch = Class.create();
watch.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getEmail: function()
		var abc=[];
		var arr=[];
		var et = this.getParameter('sysparm_user_name');
		gs.log('value of is val length'+et);
		var res = et.split(',');
		gs.log('length of array is'+res.length);
		for(var i=0;i<res.length;i++){
		var gr = new GlideRecord('cmdb_ci');
		gr.get('sys_id',res[i]);
		abc.push(gr.u_environment);
		return abc.join(',');
	type: 'watch'
Client Script:
	var abc= g_form.getValue('u_related_ci').toString();
	var ga = new GlideAjax('watch');
	ga.addParam('sysparm_name', 'getEmail');
	ga.addParam('sysparm_user_name', abc);
	ga.getXML(HelloWorldParse);
	function HelloWorldParse(response) {
		g_form.setValue('u_server_env',answer);
This script works! Thanks!
