Help: How to remove reference icon on specific fields of catalog item?
Snehal2
Hi developers,
Can any one help me on How to remove reference icon(which appears on reference field) on specific fields of catalog item.
Snehal m
24 REPLIES 24
you can create a onload script
function onLoad() {
$j('.icon-info').hide();
Swapnil Soni1
Giga Guru
Hi Snehal,
Please try this-
  1. Navigate to System Definition > Dictionary
  2. Filter the list to find the reference field of which you want to disable the information icon
  3. Open the record (eg. Caller)
  4. Add this line to the Attributes: ref_decoration_disabled=true
  5. Save/Update the record
       Please mark correct or helpful if this helps you.
Swapnil
Hi Swapnil,
This solution you suggested can be used on the normal variables. But I want to hide reference icon on the catalog variable.
Snehal
Pratiksha
add variable attribute ref_decoration_disabled=true
