Help on replacing the values through Business rules
05-13-2026 08:18 PM
HI All
I will get an value in the last logged in user field in computer table I need to trim that and need to check the same in user_id in the user table. Example value is: abc@example.com. ABC is the user id value or RF ID in user table.
If the value is not present in user_id then I need to check RF ID value in user table. Now my requirement is if the value is not present/unavailable in the user table in both user_id and RF ID I need to clear the value from most frequent logged in user in computer table.
05-13-2026 11:54 PM
update your BR script as this
Try to add logs as per your preference to debug
(function executeRule(current, previous) {
if (!current.most_frequent_user.changes())
var v = current.most_frequent_user.toString().trim();
var key = v ? v.split('@')[0].trim() : '';
var usr = new GlideRecord('sys_user');
if (!key) {
current.setValue('u_last_logged_in_user', '');
current.setValue('most_frequent_user', '');
usr.addQuery('user_id', key).addOrCondition('u_rf_id', key); // replace u_rf_id with your RF ID field
usr.setLimit(1);
usr.query();
if (usr.next())
current.setValue('u_last_logged_in_user', usr.getUniqueValue());
else {
})(current, previous);
05-13-2026 08:52 PM
Try this code snippet from BR. It will work. Update query with correct field name as per your instance.
var loggedinUserEmail = current.u_logged_in_user;
var loggedinUserEmailSplit = loggedinUserEmail.split('@');
var loggedinUserEmailSplitb4atDrate = loggedinUserEmailSplit[0] + '@example.com';
var loggedinUserEmailSplitb4atDrate1 = loggedinUserEmailSplit[0] + '@example.'; // sometime co.in is also there, avoid it if you dont have these kind of data
var userGr = new GlideRecord('sys_user');
userGr.addEncodedQuery('email=' + loggedinUserEmail + '^ORuser_idSTARTSWITH' + loggedinUserEmailSplitb4atDrate + '^ORuser_idSTARTSWITH' + loggedinUserEmailSplitb4atDrate1 + '^ORu_rf_id=' + loggedinUserEmailSplitb4atDrate + '^ORu_rf_id=' + loggedinUserEmailSplitb4atDrate1 );
userGr.orderByDesc('sys_created_on');
userGr.query();
if (userGr.next()) {
current.user = userGr.sys_id.toString();
05-13-2026 10:53 PM
Hi @Tanushree Maiti :
I need to check the RF ID and user id from user table based on the value populated in last logged in user. if value is not present in either of the field I need to clear the value from frequent logged in user in computer table
05-13-2026 10:59 PM
In that case,
In query , just search by email in user table ( modify the query) .
When it is matching the record , and returning the result , at last line -check your value using appending two line. Use the value wherever you want.
gs.log ( userGr.user_id.toString());
gs.log ( userGr.u_rf_id.toString());
