Help with a Business Rule to Not Display Empty Variables from a Record Producer on a Certain Table
Wendy Peterson
Giga Guru
Hi, I have a table called AOM Bandwidth (u_aom_bandwidth) and i need to hide variables that are empty. I copied a script from our request table but it's not working. Any ideas? See the table has the variables on it and its looking for the sys id of that table not sure what is wrong? I even tried to update the Table line to look for that specific sys id... that didn't work either
producerVars.addQuery('table_sys_id', '786da04313034f00561059812244b063');//removed current.sys_id
The Business Rule is on Display
if((!(RP==null))&&!RP.isPopup()){
//Initialize the scratchpad variable
g_scratchpad.emptyVars = '';
//Check to see if a variable pool exists
var count = 0;
for(vars in current.variable_pool){
      count++;
      break;
//If a variable pool exists then collect empty variable names
if(count > 0){
      var emptyVars = new Array();
      var table = current.getTableName();
      //Query for the empty variables for this record
      if(table == 'u_aom_bandwidth'){
            //All other variables pulled from 'question_answer' table
            var producerVars = new GlideRecord('question_answer');
            producerVars.addQuery('table_sys_id', current.sys_id);
            producerVars.addNullQuery('value');
            //Exclude Label and Container variables
            producerVars.addQuery('question.type', '!=', 11);
            producerVars.addQuery('question.type', '!=', 19);
            producerVars.addQuery('question.type', '!=', 20);
            producerVars.query();
            while(producerVars.next()){
                  //Add variable names to the emptyVars array
                  emptyVars.push(producerVars.question.name.toString());
    //Store the result in the scratchpad
      g_scratchpad.emptyVars = emptyVars.join();
eval can be harmful.
Here's my client script, for comparison:
function onLoad() {
//Hide all empty variables using the scratchpad object passed from 'Hide Empty Variables' business rule
if(g_scratchpad.emptyVars != ''){
var emptyVars = g_scratchpad.emptyVars.split(',');
for(i = 0; i < emptyVars.length; i++){
g_form.setDisplay('variables.' + emptyVars[i], false);
I wish I could help troubleshoot more in depth!
I think it might be something with the onLoad client script cause when I run debug it keeps telling me that emptyVars is undefined. shrug
