Help with Bulk Updating Most Recent Discovery Field Using Catalog Item and Excel template
Hi all,
I am trying to bulk update the Most Recent Discovery field on the CMDB CI table using a Catalog Item with an attached Excel file. The Excel file contains three fields:
 IP Address
MAC Address
Requirement:
I want to update the Most Recent Discovery field when either the Primary IP Address or MAC Address from the Excel file matches the corresponding field in the CMDB CI table. If either one matches, the update should occur.
Current Approach:
1. I am using Conditional Coalesce on the sys_id field in transform Map.
2. I created a field map where the target field is sys_id and the source is a source script.
3. In the source script, I am using a GlideRecord query on the CMDB CI table to check for a match:
MAC Address == source.MAC Address OR
IP Address == source.IP Address
4. If a match is found, the sys_id is returned, and the Most Recent Discovery field is updated. (Coalesce True on SysID field)
Issue:
This approach works fine when there is a unique match. However, when the same IP Address is associated with multiple CIs, only the first matched record gets updated. This is because:
The field mapping is only for sys_id, which is unique.
If multiple matches are found, either only the first record gets updated or no record gets updated (due to ambiguity).
FYR I have used the same kind of source Script PFB, modified as per mine condition.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0860511
Question:
How can I update the Most Recent Discovery field for all matching records when multiple CIs have the same IP Address or MAC Address?
I appreciate any guidance on how to handle this scenario.
Thank you!
Ankur Bawiskar
@Community Alums
suggestions
1) don't use field map and don't use coalesce
2) handle completely with onBefore transform script which gives you the liberty to sort by ascending or descending i.e. most recently field
3) use normal GlideRecord, query and if query finds record, go ahead and update
4) if not then create new one
5) ensure you set ignore = true so that it doesn't create a record via import set
something like this
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	// query
	// if found then update
	// if not found then insert
	ignore = true; // use this line as last line
})(source, map, log, target);
@Community Alums
It all depends on how many target records are there in the table you are querying
If table is huge query will take long time.
