Help with Catalog Client Script
Jen11
I need help with a catalog client script.  For the ''Operational work type' drop down, whatever that is selected there, I would like the 'Work category' drop down to to change to the same thing.  The choices for both the drop down are the same, but the value is different.
Thank you in advance for any help.
Ankur Bawiskar
@Jen11
if the label is same but choice value is different then you will have to use if else in your onChange of 1st field
something like this
    if (!isLoading || newValue == '') {
    if (newValue == 'ABC')
        g_form.setValue('field2', 'yourChoiceValue1');
    else if (newValue == 'DEF')
        g_form.setValue('field2', 'yourChoiceValue2');
