08-13-2018 12:20 AM
Hi all,
I have a record producer that I want to copy some variables over to the work notes.
I found the thread below which shows how and have it working with plain text, however, I am having issues with reference fields.
When I add a reference field as a variable, the script does not run and I don't even get the Variables: in the work notes. Here is the script:
var wn = 'Variables:';
for (var key in producer)
if (producer[key]) {
if (key.search('boom') != -1) {
var v = producer[key];
wn += '\n' + v.getGlideObject().getQuestion().getLabel() + ': ' + v.getDisplayValue();
current.work_notes = wn;
Any ideas?
Thanks, Brendan
Scripting and Coding
08-15-2018 09:20 PM
Ok. I thought you were using the question Label. Lets try this
var desc = '';
var qtype = 0;
var q = new GlideRecord('question_answer');
q.addQuery('table_sys_id',current.sys_id);
q.orderBy('order');
q.query();
while (q.next())
if (q.value!='' && q.question.name.indexOf('boom')>-1 && q.value!='false' || q.question.type==11)
if (q.question.type==11)
desc = desc+'\n';
if (q.question.type!=7)
if (desc=='')
desc = q.question.getDisplayValue()+': '+getRefValue(q.question.type,q.question.reference,q.value);
else
desc = desc+'\n'+q.question.getDisplayValue()+': '+getRefValue(q.question.type,q.question.reference,q.value);
else
if (qtype==7)
desc = desc+','+q.question.getDisplayValue();
else
desc = desc+' '+q.question.getDisplayValue();
qtype = q.question.type;
if (q.question.type==19)
desc = desc+'\n';
if (desc!='')
current.description = desc;
})(current, previous);
function getRefValue(type,table,value)
if (type==8)
var ref = new GlideRecord(table);
ref.get(value);
return ref.getDisplayValue();
else
return value;
08-13-2018 05:51 PM
You can try below code
var desc = '';
var qtype = 0;
q.orderBy('order');
q.query();
while (q.next())
if (q.value!='' && q.value.indexOf('boom')>-1 && q.value!='false' || q.question.type==11)
desc = desc+'\n';
if (desc=='')
else
else
if (qtype==7)
else
desc = desc+'\n';
if (desc!='')
if (type==8)
ref.get(value);
else
return value;
08-15-2018 10:47 AM
Did it work for you? Can you mark it answered if it did and close the thread
08-15-2018 04:39 PM
Hi Sanjiv,
I missed your notification the other day, so didn't know that you had written back, sorry!
I tried it, however, no variables were posted to the description.
I have verified that the variables are called 'boom_test_1' and 'boom_test_2'.
From the other script, they use the following:
I just wonder if q.value.indexOf('boom') is looking for a variable called boom and not one that contains the word boom?
08-15-2018 08:54 PM
Corrected my script
var desc = '';
var qtype = 0;
q.orderBy('order');
q.query();
while (q.next())
if (q.value!='' && q.question.question_text.indexOf('boom')>-1 && q.value!='false' || q.question.type==11)
desc = desc+'\n';
if (desc=='')
else
else
if (qtype==7)
else
desc = desc+'\n';
if (desc!='')
if (type==8)
ref.get(value);
else
return value;
08-15-2018 09:14 PM
Hey mate, thanks for getting back to me.
I have tried the amended script, however, still, nothing gets posted into the description.
