Help with Encoded query in flow designer
Snowman15
Giga Guru
Hi everyone,
I'm working on a Flow Designer script in ServiceNow where I build an encoded query to filter records. One of the conditions I need is to exclude any records on the sys_email table where the recipients field  contains @hotmail
I’ve tried the following variations but none of these seem to work:
If I remove that condition, flow works correctly. Any idea what's happening?
Here is the full script:
var gdt = new GlideDateTime();
var ms = 65 * 60 * 1000; // 65 minutes in milliseconds
gdt.add(-ms); // subtract 65 minutes
 var encodedQuery = [
'u_accountISEMPTY',
'mailbox=sent',
'sys_created_on>=' + gdt.getValue(),
'target_tableSTARTSWITHsn_customerservice',
'target_tableENDSWITHcase',
'recipientsNOT LIKE@hotmail'
].join('^');
return encodedQuery;
Snowman15
Giga Guru
Hi @Ankur Bawiskar  that didn't work either, for some reason when adding that condition, the look up always returns 0 results. I have now found a workaround to filter those records out by adding a step after that, not ideal but did the job. Thanks all.
9 REPLIES 9
Ravi Gaurav
Hi @Snowman15
Can you check the below code ?
'u_accountISEMPTY',
'mailbox=sent',
'recipients!LIKE@hotmail'
].join('^');
If you found my response helpful, I would greatly appreciate it if you could mark it as "Accepted Solution" and "Helpful."
Your support not only benefits the community but also encourages me to continue assisting. Thank you so much!
Thanks and Regards
Ravi Gaurav | ServiceNow MVP 2025,2024 | ServiceNow Practice Lead | Solution Architect
CGI
M.Tech in Data Science & AI
 YouTube: https://www.youtube.com/@learnservicenowwithravi
 LinkedIn: https://www.linkedin.com/in/ravi-gaurav-a67542aa/
@Ravi Gaurav that didn't work but thanks
Ankur Bawiskar
@Snowman15
it works fine here so it should work there as well
Did you hard-code that encodedquery in background script and see if that works?
Ankur Bawiskar
@Snowman15
try this once -> use wild card along with NOT LIKE operator
'u_accountISEMPTY',
'mailbox=sent',
'recipientsNOT LIKE%@hotmail%'
].join('^');
Snowman15
Giga Guru
