Help with flow designer
Abhijit Das7
I am using flow designer to create flow to translate knowledge article during creating knowledge article :
1. Right now I am working to translate short description of knowledge article.
2. I am not understanding how to translate article body of knowledge article
Flow Designer :
Trigger :
Action : Translate Text (short description )
If I am populating target language manually ( static , eg ; es - spanish ) then the short description is translating. But when I am using language data pill to select language dynamically then short description is either not translating or becoming empty.
Action : Update Record
I am populating short description using script :
**Access Flow/Action data using the fd_data object. Script must return a value.
**example: var shortDesc = fd_data.trigger.current.short_description;
**return shortDesc;
var languageArray = fd_data._1__translate_text.translations;
var translatedShort = languageArray[0].translatedText;
return translatedShort;
Please help me translating short description of knowledge article using language data pill and how can I translate article body of knowledge article .
Thanks in advance
FredricS
I'm also having this problem, anyone knows a solution?
