Help with script in custom flow action - need to return value with date & time
Lon Landry4
I have a custom action for flow designer that nearly works, the correct date is returned but no time.
Action - Set date to first of month
Inputs:
Label Next audit date & Name u_next_audit_date with Type Date/Time
Script step
Outputs:
First of month date (ill from script step)
Warning in script step.
Encountered undeclared output variable: result_date_time
What is returned - (Correct date but no time stamp...)
Any ideas?
Lon Landry4
 will try another question - I am now further back from where I started... 😞
Now, nothing works so a big step back...
Joshv3707220614
The warning is most likely because your script is using outputs.result_date_time, but it's not defined as an output for that script (bottom part: Output Variables).
