Help with Transform script returning Undefined
mdjoseph12
Giga Contributor
Im calculating whether the dates coming within the imports are today or later and based upon that value it'll  determine what to set the field map too, but I am continuing to receive undefined:
answer = (function transformEntry(source) {
	var today = new GlideDate();
	var stage;
	var year = today.addYears(1);
	if (source.u_date_type =="Construction Start") {
		var date = source.u_actual_start_date;
		if (date >= today) {
			stage = "Under Construction";
	} else if (source.u_date_type =="Reopen Date") {
		var dates = source.u_actual_start_date;
		if (dates >= today) {
			stage = "Re-opened";
		} else if (dates >= year) {
			stage = "Complete";
	return stage; // return the value to be put into the target field
})(source);
dvp
Try this
	var stage;
	var today = new GlideDateTime();
	var year = new GlideDateTime();
	year.addYears(1);
	var actual = new GlideDateTime(source.u_actual_start_date);
	var diff = gs.dateDiff(today, actual, true);
		if (diff >= 0) {
		//Update the below logic as the above one
			stage = "Complete";
})(source);
Prateek kumar
Try?
	var stage;
	var year = new GlideDate();
            year.addYears(1);
			stage = "Complete";
})(source);
Thanks Prateek, unfortunately the stage is coming in as undefined
