Help with User Criteria Advanced Script
jlaue
Hello - I am working on a User Criteria requirement for a Catalog Item that I am adding.  We have a custom field on the sys_user table called:  u_job_code.   I only want users with a specific job code to see this catalog item.  This u_job_code field is not a reference field.
I was wondering how I would be able to script that in the Advanced script box of the User Criteria record for this.  I would like it to filter for users where the u_jobe_code = 1000
Thanks!!
Sorry ...Correction in code. Didnt add a space after function in previous script
checkCondition();
function checkCondition(){
var user = new GlideRecord('sys_user');
user.get(gs.getUserID());
if (user.u_job_code==1000)
     return true;
return false;
9 REPLIES 9
Hi Winston,
can you provide your script and how you used "user_id"?
thanks!
This should be it:
checkCondition();
function checkCondition() {
user.get(user_id);
if(user.u_custom_field == true) {
return true;
return false;
Per the documentation:
  • Do not use gs.getUser() or other session APIs since they cause conflict when used in diagnostic tools. Use the pre-defined user_id variable available in the script to get the user id of the user being used to evaluate the script.
jlaue
That worked!  Thank you!!
Shaziya Sayed
Hello - I am working on a User Criteria requirement.
Can anyone help me with the script part.
Requirement is :
Catalog items are classified based on IT and Non-IT Services.
A new User Criteria record for IT Service-related catalog items will be created with below condition –
User’s Department= ”IT” OR
Parent Department of User Department’s = ”IT” OR
User’s Manager Department= ”IT”
