How can we create Problem Task automatically when problem record is moved to Root cause analysis state?
Shikha puri
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
Example below
32 REPLIES 32
Thomas Lindenho
Giga Guru
Hi Shikha,
I would use a flow for that, something like:
Kind regards
Thomas
HI Thomas,
I used Create Task core under workflow :
HI Thomas,
Thanks for your help , it's really helpful.
Akanksha Gupta2
Mega Guru
Hi Shikha,
You can create UI action for this,
Please Mark Correct or helpful.
Akanksha
