‎05-28-2021 04:23 AM
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
‎05-28-2021 06:22 AM
‎05-28-2021 05:51 AM
when your Priority is 5-Planning you don't want it to create.
So update the workflow condition accordingly.
‎05-28-2021 05:52 AM
will you please help me that how can I create that workflow with the help of screenshots ?
‎05-28-2021 06:04 AM
Sorry now I have created the Flow designer as mentioned by thomas now HOw can I link that task with problem , Will you please explain it ?
‎05-28-2021 06:19 AM
When you use Create Record Action set the field value
Problem -> Problem Trigger Record
you can map it using the data pills
Will you please elaborate this with the help of screenshot ?
