How can we create Problem Task automatically when problem record is moved to Root cause analysis state?
Shikha puri
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
Example below
32 REPLIES 32
Please check below comment
Example below
I have created the same but it's not working.
Please correct me if anything is wrong.
1 step
2nd step
3rd step
Please check
HI Ankur,
Task is only created when I run the Flow designer but I want that Once I move on state RCA task will be created automatically.
why 2 tasks are created using 2 actions?
only use 1 action i.e. create problem task
Also save and activate your flow.
Then change some problem to Root cause which is not having Priority = 5-Planning
Then flow will run and create problem task
