‎05-28-2021 04:23 AM
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
‎05-28-2021 06:22 AM
‎05-28-2021 07:57 AM
‎05-28-2021 08:19 AM
Glad to know.
Would you mind marking my response as correct if I was able to help you.
you can set whichever fields on problem_task record using the Set Field Value present under Create record.
‎05-28-2021 08:34 AM
‎05-29-2021 01:01 AM
yes looks good.
Please save and activate the flow and then test
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
