‎05-28-2021 04:23 AM
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
‎05-28-2021 06:22 AM
‎05-29-2021 01:42 AM
HI Ankur ,
It's working and some values are also coming from problem to problem task like assignment group ,priority etc.
but what about these values :
‎05-29-2021 01:47 AM
how you mapped group, short description
do the same for other fields.
for choice field ensure choice values are same in both the tables.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
‎05-29-2021 02:01 AM
I used the below steps :
and raise a problem :
got same values under Problem task
but my concern is I want to set Solution plan task under Short description and description field when problem task is raised , and here if any person raise the problem it's not compulsory that every person enter that value in problem .
Also here I set Solution plan as a default value of TYPE field .
Now please suggest anything for this .
‎05-29-2021 02:43 AM
HI Ankur,
Please suggest ...
That how can I get these values under Task only not in problem.
‎05-29-2021 03:02 AM
