‎05-28-2021 04:23 AM
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
‎05-28-2021 06:22 AM
‎05-29-2021 07:08 AM
Did you mistakenly marked other response as correct?
Would you mind marking my response as correct as I was able to guide you through the steps and was responding to your questions.
‎05-31-2021 12:25 AM
HI Ankur ,
It's done !
Will you please help me also for my second question as well.
Link is below for the second question.
https://community.servicenow.com/community?id=community_question&sys_id=1158441b1b583010d01143f6fe4bcb4c
‎02-08-2022 08:43 AM
how to populate description of problem to problem task in the same flow ?
