How enable to flow context view for flow designer in Washington DC
sri83
Hi All
I am  using the Washington DC version and have created the new test flow and tried to check the flow context details after executed the flow but unable to see those details whether the flow is structed or processed  please help me is there any property to enable in new instance?
Astik Thombare
Tera Sage
Hi @sri83 ,
Please navigate to Flow Administration>>Settings and in the list check if your flow is added to the list. If not then add your flow in the list and enable reporting on it. Once added, subsequent executions of the flow will show you the context.
AstikThombare_0-1720060202629.pngAstikThombare_1-1720060212061.pngAstikThombare_2-1720060224705.pngAstikThombare_3-1720060233133.png
    If my reply helped with your issue please mark helpful 👍 and correct ✔️ if your issue is resolved.
                         By doing so you help other community members find resolved questions which may relate to an issue they're having
Astik
