11-08-2019 09:07 AM
I need help to add help text to check box type variable.
Help text contain the url of another catalog item. I tried with onLoad catalog client script but it didn't work as expected.
function onLoad() {
g_form.showFieldMsg('varaible_name','text ..............' , 'info');
FYI - When I tried this script I got below message.
11-12-2019 10:33 PM
It seems field message doesn't allow url to be shown
can you try to do this using annotations
right click form -> configure form layout
add annotation just below the field you want to show the url; in the annotation add the url you want
11-12-2019 10:33 PM
11-09-2019 07:56 AM
Please refer below link,It will help you,
https://hi.service-now.com/kb_view.do?sysparm_article=KB0712308
Please Mark as correct and helpful,If you find any help.
11-15-2019 05:22 PM
You can create new Label field just above or below the checkbox variable and use Annotation tab to add your help text. You can evem customize the text by using HTML / CSS
PS : Make sure that your label filed has as same order as your checkbox variable
