How to add help text under radio field choices?
omsa1
Hi ,
I want to add help text under the choice as in the example below,how to do it?
Omkar Mone
Hi
Check the below link -
https://hi.service-now.com/kb_view.do?sysparm_article=KB0712308
It is not available for Checkbox variable.
Hope this helps.
Omkar Mone
it should be variable name .
g_form.showFieldMsg('variable name','Request Access to System','info');
eg: if you see you have a variable "What can we help you with" , that variable name mention in script.
Omkar Mone
Hi
Hope this helps.
Omkar Mone
agreed. but the screenshot it has mentioned for "Multiple Choice" type variable.
Note: check box will appear in rectangular box and multiple choice will appear in round shape.
