02-15-2026 09:15 PM
Hi Team,
I have a requirement to visually highlight VIP users on the Requested Item (RITM) form.
📌 Requirement
On the Requested Item [sc_req_item] form:
- Field: Requested for (requested_for)
- If the selected user has VIP = true (in sys_user.vip):
- Show a VIP icon / decoration on the field, and optionally
- Change the field text color (e.g., red) to make it stand out
- If the user is not VIP:
- No VIP indicator / normal display
This needs to work both when:
- The RITM is opened (onLoad)
- The Requested for field is changed by the user (onChange)
can anyone please help me - how to achieve this requriment .
thanks in advance
02-15-2026 10:34 PM
This is for sc_task.
1. Onload client script :
code: Client script (script include already shared)
function onLoad() {
var reqLabel = g_form.getLabel("request_item.requested_for");
var reqField = g_form.getDisplayBox("request_item.requested_for");
var innerHtml = "<span id=\"status.sc_task.request_item.requested_for\" title=\"On behalf of another individual\" mandatory=\"false\" oclass=\"\" aria-label=\"\" class=\" required-marker\"></span><span title=\"On behalf of another individual\" class=\"label-text\" data-html=\"false\">Requested for</span>";
if (!reqLabel || !reqField){
if (g_form.getValue("request_item.requested_for")!=null){
if(!g_scratchpad.u_vip){
var ga = new GlideAjax('CallerVIP');
ga.addParam('sysparm_name','getVIP');
ga.addParam('sysparm_caller', g_form.getValue("request_item.requested_for"));
ga.getXMLAnswer(vipTaskCallback);
else {
vipTaskCallback(g_scratchpad);
else {
removeTaskVIPStyles(reqLabel, reqField);
function vipTaskCallback(requestedFor) {
if (!requestedFor.u_vip){
requestedFor = requestedFor.evalJSON();
//check for VIP status
if (requestedFor.u_vip.toString() == 'true') {
setTaskVIPStyles(reqLabel, reqField);
else {
function setTaskVIPStyles(label, field){
if (label) {
label.innerHTML = "<img src='images/icons/vip.gif'/>" + label.innerHTML;
//change the caller's name field to red text
if (field) {
field.style.color='red';
function removeTaskVIPStyles(label, field){
if (label) {
label.innerHTML = innerHtml;
if (field) {
field.style.color = '';
3. Style on sc_task : do it same way as ritm is done.
02-16-2026 01:38 AM
It's an easy requirement.
I suggested to check OOTB client script on incident table
No need of GlideAjax and script Include
this client script should work for RITM
I simply made changes to the OOTB client script, changed script, changed table, field name and Did Insert and Stay
Then made "Isolate Script" = False
var callerLabel = $('label.sc_req_item.requested_for');
var callerField = $('sys_display.sc_req_item.requested_for');
if (!callerLabel || !callerField)
if (!newValue) {
callerLabel.setStyle({backgroundImage: ""});
callerField.setStyle({color: ""});
g_form.getReference('requested_for', vipCallerCallback);
function vipCallerCallback(caller) {
var callerLabel = $('label.sc_req_item.requested_for').down('label');
if (caller.vip == 'true') {
var bgPosition = "95% 55%";
if (document.documentElement.getAttribute('data-doctype') == 'true')
bgPosition = "5% 45%";
callerLabel.setStyle({backgroundImage: "url(images/icons/vip.gif)", backgroundRepeat: "no-repeat", backgroundPosition: bgPosition, paddingLeft: '30px' });
callerField.setStyle({color: "red"});
Output
02-15-2026 10:15 PM
check this link and enhance
Show VIP flag for Requested for on REQUEST, RITM and on task?
02-16-2026 12:27 AM
You are a Mega Sage and you are asking how to apply something on sc_task while the solution already is given for incident and ritm. You can't make that translation?
