How to calculate difference between two dates and show it on DAYS?
reinaldo_vieira
Hello!
I'm working on a challenge that asks me to calculate the date difference in 2 fields of a Service Portal form and impose form blocks and error-type messages depending on the result.
The two fields in the form are of type Date (not Date/Time).
Can this be done directly via Client Script or is it better to use a combination of Script Include GlideAJAX Script + Catalog Client Script onChange?
IMPORTANT:
- The date in "data_inicio_emprestimo" CANNOT be less than the current date. If it is, the field will display an error message and the form cannot be submitted.
- The date difference between the fields (data_inicio_emprestimo / data_final_emprestimo) must be a maximum of 7 days. If the difference is greater than 7 days, the field will display an error text message and the form cannot be submitted.
HII @reinaldo_vieira
I have worked this script based on your requirement,here is the script and code
Scriptinclude:
var Diff_date = Class.create();
Diff_date.prototype = Object.extendsObject(AbstractAjaxProcessor, {
  calculatedate: function() {
              var startDate = new GlideDate();
              startDate.setDisplayValue(this.getParameter('sysparm_start'));
              var endDate = new GlideDate();
              endDate.setDisplayValue(this.getParameter('sysparm_end'));
              var duration = new GlideDuration();
              duration= GlideDate.subtract(startDate, endDate);
              return duration.getDayPart();
    type: 'Diff_date'
ClientScript:
var startDate = g_form.getValue('start_date');
var endDate = newValue;
var maxDays = 7;
//maxDays.setDisplayValue(7);
alert(maxDays);
alert(startDate);
alert(endDate);
var ga = new GlideAjax('global.Diff_date');
ga.addParam('sysparm_name', 'calculatedate');
ga.addParam('sysparm_start', startDate);
ga.addParam('sysparm_end', endDate);
ga.getXML(callback);
function callback(response) {
var answer = response.responseXML.documentElement.getAttribute('answer');
alert(answer);
if (answer > maxDays) {
    alert('test');
g_form.showFieldMsg('end_date', 'Você ultrapassou o limite de 7 dias. Por favor, escolha um período mais curto', 'error');
alert('Deu errado...'); //to check if Script Include and Client Script are running ok
   Screenshots:
SHARANsnow7_0-1697116313852.pngSHARANsnow7_1-1697116338887.pngSHARANsnow7_2-1697116381859.png
Mark my answer helpful & accepted if it helps you resolve your query.
Sharan
Hello, @Community Alums
I tried getXML but unfortunately it didn't work. From what I read later in this article, I think getXMLAnswer was a better fit for my attempt.
I'll share the code that worked for me.
Reinaldo Vieira
SCRIPT INCLUDE
var DifferDates = Class.create();
DifferDates.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    calcularDias: function() {
        var from = new GlideDate();
        from.setDisplayValue(this._transformDate(this.getParameter('sysparm_start'))); //define um valor de data usando o formato de exibição e o fuso horário do usuário atual
        var to = new GlideDate();
        to.setDisplayValue(this._transformDate(this.getParameter('sysparm_end')));
        var difference = GlideDate.subtract(from, to);
        var days = difference.getDayPart(); //retorna o número de dias
        return days;
    _transformDate: function(date) {
        date = date.split('/');
        return date = date[2] + '-' + date[1] + '-' + date[0];
    type: 'DifferDates'
CLIENT SCRIPT
    var startDate = g_form.getValue('data_inicio_emprestimo');
    var endDate = g_form.getValue('data_final_emprestimo');
    var maxDays = 7;
    var ga = new GlideAjax('global.DifferDates');
    ga.addParam('sysparm_name', 'calcularDias');
    ga.getXMLAnswer(callback);
        if (response > maxDays) {
            g_form.showFieldMsg('data_final_emprestimo', 'Você ultrapassou o limite de 7 dias. Por favor, escolha um período mais curto.', 'error');
Hello, @Jagadish Sanadi
I've tested up here with some other conversations on the subject and I like this solution. I would also add an internal function to the Include script to transform the date - in the GlideDate documentation, the expected format for the subtract is yyyy-MM-dd.
Best regards,
Reinaldo Vieira
var answer = response.responsexml.documentelement.getattribute( answer );
if(answer>maxDays)
Please check this and mark useful if this helped you
