How to call array from my system property?
02-19-2026 08:08 AM
Hi everyone,
I'm working with a system property that stores an array of string values, for example:
Property: list.of.strings
Values: "111 - TEST", "112 - Test2"
In my Script Include, I'm retrieving the property like this:
var titles = gs.getProperty('list.of.strings');
I’d like to use these values to query a table with GlideRecord and filter records based on them.
Has anyone done this before or knows the best way to parse and use these property values in a GlideRecord query?
Thanks!
02-19-2026 10:35 PM
Hello @saint ,
Just simply change little bit code like
var titlesArray = titles.replace(/^"|"$/g, '').split('","');
then try this
var gr = new GlideRecord('<table>');
if (titlesArray.length > 0) {
gr.addQuery('your_field', titlesArray[0]);
for (var i = 1; i < titlesArray.length; i++) {
gr.addOrCondition('your_field', titlesArray[i]);
If this helps you then mark it as helpful and accept as solution.
Aditya
02-19-2026 10:36 PM
that replace method code line will give you output like this.
02-20-2026 07:36 AM
Hello @saint ,
I hope you are doing well . Does my response helps you ?
Aditya
02-19-2026 09:16 AM
Hi @saint ,
Try below script
var propValue = gs.getProperty('list.of.strings', '');
var spl = propValue.split(',');
for (var i = 0; i < spl.length; i++) {
var gr = new GlideRecord('your_table_name');
gr.addQuery('your_field_name', spl[i].trim());
while (gr.next()) {
gs.info(gr.getDisplayValue('your_field_name'));
If my response helped, please mark it as the accepted solution ✅ and give a thumbs up👍.
Anand
02-19-2026 09:28 PM
you are already storing it as string with comma separated values
simply use this
gr.addEncodedQuery('nameIN' + gs.getProperty('list.of.strings'));
