How to call array from my system property?
saint
Hi everyone,
I'm working with a system property that stores an array of string values, for example:
Property: list.of.strings
Values: "111 - TEST", "112 - Test2"
In my Script Include, I'm retrieving the property like this:
var titles = gs.getProperty('list.of.strings');
I’d like to use these values to query a table with GlideRecord and filter records based on them.
Has anyone done this before or knows the best way to parse and use these property values in a GlideRecord query?
Thanks!
13 REPLIES 13
@saint
Hope you are doing good.
Tanushree Maiti
Hi @saint ,
Try this.
var propValue = gs.getProperty('list.of.strings');
if (propValue) {
     var valuesArray = propValue.split(',');
    var gr = new GlideRecord('your_table_name');
    gr.addQuery('your_field_name', 'IN', valuesArray.join(','));
    while (gr.next())
            gs.info("Found record: " + gr.getDisplayValue());
    gs.warn("System property 'list.of.strings' not found or is empty.");
cohlandt
If you trying to do assume each value has two parts try this script. I used Code and Description but you can change those and set them to other things as well not just gs.info.
if (titles) {
var titlesArray = titles.split(',');
for (var i = 0; i < titlesArray.length; i++) {
var value = titlesArray[i].trim();
gs.info('Full Value: ' + value);
// Optional: split number and description
if (value.indexOf(' - ') > -1) {
var parts = value.split(' - ');
var code = parts[0].trim();
var description = parts[1].trim();
gs.info('Code: ' + code);
gs.info('Description: ' + description);
You can use the split value as '","'
