how to check state of an flow when completed and error caught
Raviteja Kunal1
Hi All
I am trying to trigger an sub flow from UI action. How to get status of the sub flow if it is completed or completed (with caught error). I need this information to process further.
Thank you in advance.
var result = {};
    result['condition'] = 'test';
    var gst = sn_fd.FlowAPI.getRunner()
        .subflow('retrieve_supplier_details')
        .inBackground()
        .withInputs(result)
        .run();
@Raviteja Kunal1
did you print the outputs?
Is the subflow getting triggered? did you verify that?
gs.addInfoMessage(' integration inprogress....');
var inputs = {};
inputs['condition'] = 'sys_id=' + current.getUniqueValue();
var result = sn_fd.FlowAPI.getRunner().subflow('retrieve_supplier_details').inForeground().withInputs(inputs).run();
var outputs = result.getOutputs();
gs.info('outputs is' + outputs);
yes it is updating record after sub flow is triggered when any errors causing issue as we need to log those errors
@Raviteja Kunal1
you can query sys_flow_context table with the flow name and see the state is error
did you try to give something wrong in subflow purposely and use try catch block to know if it throws any error?
@Raviteja Kunal1
did you try using try catch block as per what I mentioned earlier?
Raviteja Kunal1
yes but no error message.
