How to CLOSE a Problem Record/Ticket using Background script?
paddy786
I have used the below script, but the PROBLEM ticket is going to PENDING status & not to CLOSED status as i wanted.
var gr = new GlideRecord('problem');
gr.addQuery('number','PRB000011568');
while(gr.next())
   gr.setWorkflow(false);
   gr.problem_state= 4; //to close;
   gr.u_substatus= 'Cancelled';
   //gs.print();
   gr.update();
Can any body help me in this matter.
any help would be greatly appreciated.
- Paddy
hvrdhn88
Giga Patron
if(gr.next())
   gr.state= 4; //to close;
  gr.update();
OR
gr.addQuery('sys_id','<sys id or the record>');
if(gr.next())
   gr.state= 4; // problem field state.
  gr.update();
Note: you can try with any of the above script..
adding link below for more details about the background script functionality. in which scenario you should use it with an example kindly refer that also.
https://www.servicenowelite.com/blog/2017/8/25/code-vault/background-scripts
Nitesh Balusu
Giga Guru
This statement wouldn't be required, any reason you're using a background script to get this done?
