How to combine an advanced reference qualifier with a simple encoded query
Brett14
Giga Expert
Community,
I need to update our assignment group reference qualifier for Change Management.  Obvisouly I will need to do a dictionary override so that it is just for Change.
Can I do this below
javascript:new BackfillAssignmentGroup().BackfillAssignmentGroup() + typeNOT LIKE0c32e84cdbc95300ec5a70c08c961979
I am getting all the assignment groups now.
13 REPLIES 13
What do you see if you navigate to the following URL in your instance?  If this works, then the ref qual I provided should work.  If it doesn't, then you need to set the correct filter manually on the group table and then copy that query to use instead.
https://YOURINSTANCENAME.service-now.com/sys_user_group_list.do?sysparm_query=typeNOT LIKE0c32e84cdbc95300ec5a70c08c961979
Hi Mark,
When I navigate to the URL with my instance name I get the group table list filtered by type does not contain Approval.  I'm getting the correct list.
I agree, i thought my original ref qual should have worked, but you pointed out the '^' needed to be added.  This is weird.
The ‘^’ is just an ‘AND’ for the condition.  It needs to be there for sure because otherwise it will just add on to the comma-separated list of sys_ids that the current ref qual function returns.  I just noticed something from your original post though.  It looks like you’ve got a space in ‘NOT LIKE’.  Can you eliminate that space and try again?  To be absolutely sure, just right-click the breadcrumb link from your filtered list with the type filtering correctly and use that.
I saw that and re-copied the query and it is putting the space.  Just for testing purposes I just did a 'contains' so that I could just get typeLIKEf429f94c0a0a3c9801ecd71fa6749366  (which is a different filter condition but wanted to test).
Still no results.  I guess I will have to write a new script include for Change Only.
asifnoor
Just keep the 2nd condition into quotations and it should work.
Mark the comment as helpful and correct if it worked.
