How to define and call a shared client-side function
kevinharalson
Mega Expert
I have a 3 fields on a table's form needing to run a snippet of code when the field's value changes. The snippet obtains the necessary information from the form, and executes a GlideAjax call.
Is there any way to define this snippet of code as a client-side function for the table so the code does not have to be replicated and maintained within 3 separate onChange client scripts?
Currently:
Field 1 onChange - obtains form data and makes ajax call
Field 2 onChange - obtains form data and makes ajax call
Field 3 onChange - obtains form data and makes ajax call
Desire:
Field 1 onChange - call client-side function
Field 2 onChange - call client-side function
Field 3 onChange - call client-side function
client-side function - obtains form data and makes ajax call
Alikutty A
Tera Sage
There is one option to include your reusable client script along with an onLoad client script. These scripts are accesible within onChange client scripts.
You can try this out once
function onLoad(){
function myReusableScript(){
alert("I am in");
function onChange(){
myReusableScript();
thanks
Inacitive_User
Kilo Explorer
can it be called in OnSubmit client script?
i tried the same for the functions defined in variable Set. i was able to call them in onLoad but not onSubmit
