How to display values using of an array using for loop
jenny32
In my table there is a field "Team" of type "List". I'm selecting more than one member in that field. Now I want to display the values of that filed one after another.
code:
<td>$[escalation.u_team.getDisplayValue()]</td>
When I try to display the values using the above code, I got the result as "Quintin Isacson, Waldo Edberg".
I need the values to be displayed in the below format:
Quintin Isacson
Waldo Edberg
I used foreach tag but it is not working.
Here is the code using "foreach"
<tr>
  <td class="a2_td">
    <g:evaluate>
    var list = escalation.u_team.getDisplayValue();
        <!--var array = list.split(","); -->
    </g:evaluate>
      <j:forEach items="${list}" var="jvar_array">
        <g:evaluate jelly="true">
                      var name = jelly.jvar_array;
              </g:evaluate>
        <p>
                      User: $[SP] <span>${name}</span>
              </p>
      </j:forEach>
          </td></tr>
Any clue on how to make this code work?
Jennifer
sergiu_panaite
Hi Jennifer,
You might find this answer helpful:
Loop thought list collector
Of course, you will need to adapt the script to jelly.
Sergiu
Kalaiarasan Pus
u_team.getDisplayValue() will give a comma separated list of display values.. Split using ',' and loop through the resulting array.
Hi Kalai,
I did the same way but it is not working. When I try to display the values of array using ForEach I'm getting blank column and values are not displayed.
Here is the part of code where I use ForEach in HTML part of my UI page:
<j:jelly>
<g2:evaluate>
var escalation=new GlideRecord('u_escalation_level');
escalation.orderByDesc('u_level');
      escalation.query();
</g2:evaluate>
<g2 height="200px">
  <table class="a2_table">
  <tr>
    <th class="a2_th" width="100%"><h4><b>Escalation Level</b></h4></th>
  </tr>
</table>
<tr>
        <th class="a2_th"><h4><b>Team</b></h4></th>
</tr>
  <j2:while test="$[escalation.next()]">
      <tr>
  <td class="a2_td">
    <g:evaluate>
    var list=escalation.u_team.getDisplayValue();
var array=[];
      </g:evaluate>
      <j:forEach items="${array}" var="jvar_users">
                          var name = jelly.jvar_users;
                </g:evaluate>
              <p>
      User: $[SP} <span>${name}</span>
              </p>
      </j:forEach>
        </td>
  </tr>
      </j2:while>
  </table>
</g2>
</j:jelly>
Jenny
jancaasi
Mega Expert
Hi Jennifer,
Have you tried alerting the array[0] after you split to check if there is a value in it?
