How to display values using of an array using for loop
jenny32
In my table there is a field "Team" of type "List". I'm selecting more than one member in that field. Now I want to display the values of that filed one after another.
code:
<td>$[escalation.u_team.getDisplayValue()]</td>
When I try to display the values using the above code, I got the result as "Quintin Isacson, Waldo Edberg".
I need the values to be displayed in the below format:
Quintin Isacson
Waldo Edberg
I used foreach tag but it is not working.
Here is the code using "foreach"
<tr>
  <td class="a2_td">
    <g:evaluate>
    var list = escalation.u_team.getDisplayValue();
        <!--var array = list.split(","); -->
    </g:evaluate>
      <j:forEach items="${list}" var="jvar_array">
        <g:evaluate jelly="true">
                      var name = jelly.jvar_array;
              </g:evaluate>
        <p>
                      User: $[SP] <span>${name}</span>
              </p>
      </j:forEach>
          </td></tr>
Any clue on how to make this code work?
Jennifer
Hi Jan,
                  Value is not getting printed. According to my observation the values should be with in [' '](square brackets).
                  I tried below example and did some changes also, then finally came to know that to display values, it should be with in [].
<g:evaluate>
var colors =['red', 'yellow'];
      </g:evaluate>
      <j:forEach items="${colors}" var="jvar_color">
                        var name=jelly.jvar_color;
              </g:evaluate>
              <p>
    Color: $[SP] <span>${name}</span>
              </p>
      </j:forEach>
</j:jelly>
So, I'm not exactly getting where I'm doing mistake in my code.
Jenny
Try this code:
<g:evaluate>
      var colors = ['red', 'yellow'];
</g:evaluate>
<j:forEach items="${colors}" var="jvar_thisColor" indexVar="jvar_i">
      <g:evaluate var="jvar_s" expression="colors[${jvar_i}]" />
      <p>${jvar_s}</p>
</j:forEach>
Let me know if this helps.
-Jan Raphael Caasi
