How to filter a reference variable through client script
Ak8977
there were two variable called contractor and manager, contractor is of yes or no type. and manger is of reference type. if we select yes in the contractor then only the users whose mail id contains "@xyz.com" need to be shown in the manager field.
Vishal Birajdar
Hello @Ak8977
You just use Advanced reference qualifier on "Manager" variable like below & no need to write script include and client script :
Note : Use your variable backend name wherever necessary
javascript: var query;
if(current.variables.contractor == 'Yes'){
 query = "emailLIKE@xyz.com";
Hello @Vishal Birajdar ,
thank you very much. It works for me.
Satyapriya
Hi Vishal,
 Current.variables.variable_name is not working.
Instead of that we should use
if(current.getValue('u_contractor') == 'Yes'){
query = "emailLIKE@example.com";
Satyapriya
Hi @Ak8977
Is it working perfectly as per your requirement.
