How to Get Reference field values of a Record with Record SysId ??
Tarun2
Hi ,
I have few doubts with Scripting
1.How to  know How many Reference Fields are present in a Record ??   i have Record sysd_id
                    and
2.How to know the value of Reference Field in a Record ?   Value not  , sys_id of field .
  My  Requirement :
I have a  Table:
Schema Table has Refereence Field linked to DataBase Table .
Schema table Record_1 is Linked to Database Table Record_
With Sys_Id of Schema Table Record  i want to fetch the Related Record (i.e Database Table Record_1 name )
Thankyou ,
here i tested the script, for my incident table, same way you can do it for your table.
var gr = new GlideRecord('incident');  // change the table name
gr.addQuery('sys_id','98e902e02f6b4c10f68d5ff62799b609');  // add record id
gr.next();
var fields = gr.getFields();
for(var i = 0;i<fields.size();i++){
var glideElement = fields.get(i);
if (glideElement.hasValue()) {
if(glideElement.getED().getInternalType() == 'reference'){
gs.print(glideElement.getDisplayValue());
13 REPLIES 13
You can directly gilde particular table and pass the sys_id of the record
var gr = new GlideRecord('incident');  // table name
gr.get('7f71107c1bb60010445ffcc8cc4bcb3f'); //sys_id of record
if(gr.next())
No errors BUT
Results are bot displaying .
test136
Its working for me please check your record id is correct or not
It's working for me please check your record id whether it is correct or not
