How to insert approvals using a script
sk59
I would like to insert an approval using a BR. Please let me know how to achieve this.
I have a field ABC(glide_list), I want to add the approvers in this field as approvers when a change is completed.
Thanks in Advance
Sorry below one is the corrected script:
// Add your code here
var app = current.u_groups;//Where groups are selected
gs.addInfoMessage(app);
var spl = app.split(',');
var len = spl.length;
for(var i=0;i<len;i++)
gs.addInfoMessage(i);
var m = new GlideRecord('sysapproval_group');
m.initialize();
m.parent= current.sys_id;
m.assignment_group = spl[i];
m.approval = 'requested';
m.insert();
})(current, previous);
Ashutosh
Don't forget to mark it as correct
23 REPLIES 23
HI,
Where you have to use this script and where is your approvers stored?
Ashutosh Munot
Hi Ashutosh,
I have the glide_list field on Change table which stores the groups and I need to add them as approvers when change state is completed.
HI,
So you can write a after update BR with conditions as State changes to Completed.
var app = current.glide_list_field_name;
var m = new GlideRecord('sysapproval_approver');
m.initialize();
m.sysapproval= current.sys_id;
m.approver = spl[i];
m.state = 'requested';
m.insert();
Ashutosh Munot
HI,
This is working for me :
See Below BR:
And below is approval list:
Ashutosh Munot
Hi Ashutosh,
For your case it is working because watch list has the users. find_real_file.png
but in my case the field has the groups
