How to insert SQL code in KB's article body
Options
03-01-2023 01:50 AM
Hello! I need help!
I need to insert code into the body of a knowledge base article and I want the syntax to be recognized with colors.
SQL is not found as a valid option in the list of code examples to insert/edit. What do you recommend?
Options
03-01-2023 08:38 AM
I did find documentation on how to configure TinyMCE outside of ServiceNow. Unfortunately, I did not find something specifically for inside ServiceNow. It is a wysiwyg editor so the components that are controlling that are likely locked down and DOM manipulation is frowned upon. May want to contact HI about it if you really need it.
Sable Vimes - CSA
