How to make fields read only using Client script
shaik_irfan
I am a newbie to Snow i wrtten client script on incident but fields are not getting read only:
function onLoad() {
    alert("testing");
g_form.setReadOnly('number', true);
g_form.setReadOnly('date_format',   true);
13 REPLIES 13
paulmorris
To make a field read-only with Client Script, refer to the following code example:
function onLoad() {
g_form.setDisabled('number', true);
g_form.setDisabled('date_format',   true);
Reference: https://developer.servicenow.com/app.do#!/api_doc?v=jakarta&id=r_GlideFormSetDisabled_String_Boolean
Please Note!
There are a number of ways to make a field read only in ServiceNow.
Using a Client Script should be the last mechanism you choose once all others have been exhausted, such as
  • UI Policy
  • Data Policy
  • Acess Control
  • Dictionary Entry
If you can tell us your business requirement, we may be able to guide you to a better solution.
Paul,
Thanks for the code its not working for Number & Date Format fields, i tried with the same code for Contact type & its working but not working for Number & Date Format.
Can you please tell me what might be the reason
function onLoad() {
    alert("testing");
// g_form.setReadOnly('number', true);
// g_form.setReadOnly('date_format',   true);
g_form.setDisabled('contact_type',   true);
//g_form.setReadOnly('contact_type', true);
Hi Shaik,
setReadOnly() and setDisabled(), both should work. Can you please cross check if there is not ACL, UI Policy or any other things causing an issue?
Or Can you just increase the execution order or your client script and check.
Shishir,
Its my personal instance and there is no ACL or any UI Policy working on it
Put an alert or jslog after your code just to make sure it is running.
Something else is interfering.
