How to populate assignment group using Flow Designer f(x) script?
Erica2
I need help on how to populate assignment group based on user select dropdown variable value that contains pacific word using Flow Designer f(x) script.
This is what I have, but it did not work.  Can someone please provide suggestion.  Thank you
-O-
If using Flow anyway, why not use Decision Tables? You can then create a completely code free solution.
Define the decision table that accepts a text input to use in the condition:
AAnd the condition:
find_real_file.pngThen use it in the flow:
Using a Catalog Item variable as below:
And finally update the assignment group:
25 REPLIES 25
hvrdhn88
Giga Patron
Did you add log to check either its going inside if block or not?
Erica2
@Harshvardhan
How do you add log to check.  I have never done it.  Could you help?
For testing purposes.  Here is my f(x), but it did not work.
var av ='';
var TeamName = 'Outlook App';
if(ProjName.indexOf('Outlook') ==-1){
av += 'IT Service Desk Team';
return av;
Erica2
@Harshvardhan
Sorry, this should be the correct code
var av ='';
if(TeamName.indexOf('Outlook') ==-1){
return av;
Added logs please check now.
var av ='';
gs.log('index of check '+ TeamName.indexOf('Outlook'));
if(TeamName.indexOf('Outlook') == -1){
gs.log('Value inside if ');
return av;
