How to populate assignment group using Flow Designer f(x) script?
Erica2
I need help on how to populate assignment group based on user select dropdown variable value that contains pacific word using Flow Designer f(x) script.
This is what I have, but it did not work.  Can someone please provide suggestion.  Thank you
-O-
If using Flow anyway, why not use Decision Tables? You can then create a completely code free solution.
Define the decision table that accepts a text input to use in the condition:
AAnd the condition:
find_real_file.pngThen use it in the flow:
Using a Catalog Item variable as below:
And finally update the assignment group:
25 REPLIES 25
to check log, you need to go to log table and search with that string which i mentioned in log.
Erica2
@Harshvardhan
Is this the log table?  syslog.list
If that is the case, which column should I search for?
in the message column search with the log string,
eg: Apply filter on log table like below
message | contains | index of check
or
message | contains | Value inside if
Erica2
@Harshvardhan
I have learned something new today from you.  Thank you so much for showing that.
It never made to the log.
Did you executed your flow before checking the logs?
May i know how are you testing it?
if flow has executed then you should see the flow execution result to check either flow has executed without any error or not.
