How to populate assignment group using Flow Designer f(x) script?
Erica2
I need help on how to populate assignment group based on user select dropdown variable value that contains pacific word using Flow Designer f(x) script.
This is what I have, but it did not work.  Can someone please provide suggestion.  Thank you
-O-
If using Flow anyway, why not use Decision Tables? You can then create a completely code free solution.
Define the decision table that accepts a text input to use in the condition:
AAnd the condition:
find_real_file.pngThen use it in the flow:
Using a Catalog Item variable as below:
And finally update the assignment group:
25 REPLIES 25
OlaN
Tera Sage
Hi.
Assignment group is a reference, so if you want to populate it with a valid value, you'll need to return a sys_ID, not the name of the group from your script.
Erica2
How do I modify the following code to make it works.  Thanks
var av ='';
var TeamName = 'Outlook App';
if(TeamName.indexOf('Outlook') ==-1){
av += 'IT Service Desk Team';
return av;
You could try something like the following:
var av ='';
var groupSysID = '';
if(TeamName.indexOf('Outlook') == -1){
  av = 'IT Service Desk Team';
  var assignGR = new GlideRecord('sys_user_group');
  assignGR.addQuery('name', av);
  assigneGR.query();
  if (assignGR.next()){
    groupSysID = assignGR.getUniqueValue();
return groupSysID;
Erica2
Hi OlaN,
I have tried your suggestion and it works. However, it is not populate the value inside the Assignment group field.  Instead is shows up as a dropdown list.  End user needs to select from it.
-O-
AAnd the condition:
