How to populate assignment group using Flow Designer f(x) script?
Erica2
I need help on how to populate assignment group based on user select dropdown variable value that contains pacific word using Flow Designer f(x) script.
This is what I have, but it did not work.  Can someone please provide suggestion.  Thank you
-O-
If using Flow anyway, why not use Decision Tables? You can then create a completely code free solution.
Define the decision table that accepts a text input to use in the condition:
AAnd the condition:
find_real_file.pngThen use it in the flow:
Using a Catalog Item variable as below:
And finally update the assignment group:
25 REPLIES 25
You should not have any problems. This is a newer technology fitting the no code dogma SN is into right now.
Also glad you have figured it all out :-).
